Syvecs 50Hz GPS Module
caleb
Post by caleb »
I am trying to figure out the pin out of the Syvecs 50Hz GPS module. I found the manual online, however it only gives the pin out of 6 or 7 pins. The unit has 18 pins. Where can I find the pin outs for the other 11 pins? Or are the pins listed in the manual the only ones necessary to use the module?
Re: Syvecs 50Hz GPS Module
Only the pins in the manual are used.
caleb
Post by caleb »
Thank you! Would you happen to know why they are made with 18 pins if only 6 are used? I do not know much about this unit so I am curious.
caleb
Post by caleb »
Also, this unit has a CAN0 LOW and HI, as well as a CAN1 LOW and HI. I have read that CAN just needs 2 connections, CAN low and CAN hi, to work. Since there are 2 sets of CAN low and CAN hi here, does that mean only one pair needs to be hooked up? Or do both need to be hooked up. Thanks for the help, I truly appreciate it.
caleb wrote: Mon Jun 13, 2022 4:21 pm Thank you! Would you happen to know why they are made with 18 pins if only 6 are used? I do not know much about this unit so I am curious.
my best guess is simply to standardise on a connector they use on other products
caleb wrote: Mon Jun 13, 2022 4:26 pm Also, this unit has a CAN0 LOW and HI, as well as a CAN1 LOW and HI. I have read that CAN just needs 2 connections, CAN low and CAN hi, to work. Since there are 2 sets of CAN low and CAN hi here, does that mean only one pair needs to be hooked up? Or do both need to be hooked up. Thanks for the help, I truly appreciate it.
As the manual says - CAN0 is 1Mbit/s, CAN1 is 500kbit/s, so you would use whichever suits your CAN system
caleb
Post by caleb »
Thank you so much for the help, I really appreciate it!
mewhateful
Post by mewhateful »
Thanks for the guidance, I will use the right one for my CAN system. Useful.
drive mad
mike34
Post by mike34 »
Glad I read your post, it helped me a lot
uno online
