need some dbw help
Replica_rs4
Re: need some dbw help
Post by Replica_rs4 »
I have interesting detail to add, vbat only showing 7.3 v vs 12v ish with voltmeter at ecu power pins.
If vbat at the ECU is only 7v, quite clearly that is a major problem.
Find out why. Something with the wiring is amiss.
Exactly where did you measure 12v ?
Slowie
Post by Slowie »
These ECU's aren't known for reading battery voltage that accurately, but 7V is wrong. Hope something didn't get damaged.
You could perhaps try swapping the DBW wires to H-Bridge 3 or 4 (Slaveout 5+6 or slave out 7+8), to see if the h-bridge is damaged.
