Is it even possible to use an analogue sensor for triggering a clutch position function on an S6? The inputs available seem to only allow a switch.
Launch Control Settings
johnfelstead
Re: Launch Control Settings
I have a pressure sensor on my own car, and things are not so simple.
It is actually quite a huge variable not just on pedal position, but also how fast/slow the pedal is being moved in either direction.
A linear pot would be a lot more consistent, but not something I bothered to try yet. Using pressure for things that need fine control...nope, just too difficult IMO.
But as the "clutch switch" can be defined based on clutch pressure/position....I would assume it could be used ok with a linear pot ? and is a variable you could play with.
More recently I have added a "wheel" speed sensor onto my propshaft ( well it was there as the regular VSS on my T56 but I never used it before...VR...but seems to pick up fast, might switch to Hall later if it doesn't do what I hope ) as this should pick up "speed...ie movement in the drivetrain to switch to main launch" faster than actual wheel speeds.
Plus annoyingly since I moved my rear wheel speeds to the X10....they just do not seem as reliable as they were with direct to the S8. Hmmmm, methinks the X10 has a few niggles.
The VSS Prop speed trigger is direct to S8.
And you seem correct...I do not see clutch position or pressure in the S6.
johnfelstead
How would you do that? I cant see it as an option in the S6 software? Or are you suggesting to use the high and low trigger voltages and not a proper pressure sensor linearisation?stevieturbo wrote: Mon Apr 18, 2022 2:18 pm
johnfelstead
beat me to it.stevieturbo wrote: Mon Apr 18, 2022 2:21 pm And you seem correct...I do not see clutch position or pressure in the S6.
buy an S7 or S8 lol
johnfelstead
