Latest S8C Firmware
Re: Latest S8C Firmware
PLEASE USE 1.693 as has significant improvements
Changes Since 1.687
(in 688)
(in 690)
This Link - CLICK HERE is for version 1.693 of the S8 firmware.
Changes Since 1.678
(in 677)
(in 678)
(in 680)
* new cm map use: n2oDutyMlt
(in 682)
(in 687)
* new cm map - DBW Multiplier
* rs232 25hz transmit option
(in 688)
(in 690)
(in 693)
This Link - CLICK HERE is for version 1.699 of the S8 firmware.
Changes Since 1.693
(in 694)
* Improved overrun fuel cutoff help notes
* fuelMltOrfcEnd now 1.000 during orfc (matters since 100% fuel cut made possible in 693)
* idle target CM range increases from +1000 to +2500
* gps fault invoked by mappable quality < x
* added vehicle speed fault limp cause (new vehSpdLimp monitoring item)
* limp mode on failed vehicle speed is optional
* optional vehicle speed forced fail when gps reverts to wheel speeds
(in 696)
* limp mode on failed vehicle speed now defaults to NO (on upgrade from <694) to avoid limp when no wheel speeds configured
* new monitoring item dbwTargMax - higher of dbw1Targ and dbw2Targ
* dbwTargMax available as cm axis
* removed torque control driver demand blend out
* new cm map use: torque control driver demand adder
* option to disable torque control driver demand limit when closed loop idle active (defaults to NO)
* renamed torque control Driver Demand Torque Limit to Maximum Driver Demand Torque to avoid confusion between map and function
* torque control driver demand torque limit now disabled during gear blip trail
* new dbw limit item dbwLimitTrq; is beaten by blip (cf dbwLimitPit)
* torque control dbwLimitTrq integrator f(engTrqEstDmdMargin,dbwTargMax) max 100% min dbwTargIdle
(in 699)
* external torque conversion output maps, used to keep OEM TCM's happy by keeping torque values within OEM Limits but allows internal torque calculations to be uneffected.
*new monitoring items engTrqEstFrictionExt, engTrqEstOutputExt, engTrqEstOutputPotExt, engTrqDmdPpsExt (these are the outputs of the Torque S Curve, recommend to be sent in datastreams - Custom Can Transmit for OEM setups
*lambda heater pwm frequency adjustable
Locked
