Grayhill Canbus Keypad
torana
Post by torana »
Hello,
Has anyone or is it possible to setup a Grayhill brand canbus keypad with canopen eg a 6 button style to be connected into a syvecs ecu S7 can to operate, pushbutton functions like:
https://www.grayhill.com/productattribu ... 206-2RN3AG
logging on/off
different boost levels
rolling antilag momentary switch
cal map selections
traction control levels
Syvecs Ed
Syvecs Staff - Cleaner
Re: Grayhill Canbus Keypad
Post by Syvecs Ed »
We can support these through custom firmware. You'd need to contact support.
torana
Post by torana »
Sounds good,
Trying to do it without using a pdu
pavlo
Zen Performance
Post by pavlo »
You don' t need custom firmware to do this. You can reprogram the keypad to send data in a format the S7 or above can read on custom can import.
Lqqk
Post by Lqqk »
Is there any more information on how to do this? I’m looking to do the same.
audpwr1
Post by audpwr1 »
Bringing this to the top.
I want to run a 15 position keypad in line with a S7i (new) and Pdu X3.
Does this work pretty seamlessly? Can I make the interaction of one button work on both units (button - 3 way Radiator On/OFF/ECU controlled). This would require both the ECM and the PDU seeing this and using logic
audpwr1 wrote: Fri Mar 04, 2022 6:26 pm Bringing this to the top.
Here is a small video showing the WM pump driven by the PDUx3
and description of button programming........
https://www.youtube.com/watch?v=Hrj-PcnZVJs
