Latest Firmware Releases
Technical Help / Firmwares for the Audi R8 Gen2 and Lamborghini Huracan Awd Controllers
This thread is for tracking the firmware builds of the AWD Huracan / R8 units. When a new release is available it will be added to the end of this thread.
Any further Questions please E-mail support@syvecs.co.uk or speak to your nearest dealer
1.14.2
This is the first public release level
Firmware Version 1.14.2 - www.syvecs.com/downloads/AWD_Huracan.enc
1.15
Version 1.15 contains the following updates
*Change Light Output Pin (HBR4)
*Drive ratio calculation for Gear detection on Manual Trans cars
*Enable Gear Detection from Drive Ratio option
*Change Light Min Speed
*Change Light RPM
*Change Light Min Tps
Firmware Version 1.15.2 - www.syvecs.com/downloads/AWD_HuracanR8.enc
15.3
Version 1.15.3 contains a background change to send out the paddle up can frame for autoshift with R8
www.syvecs.com/downloads/AWD_HuracanR8_153.enc
1.18 Firmware
Changes since 1.15
1.18 - Added simple Map locking and Restriction option. - Press C, F inside a map
Firmware Version 1.18 - www.syvecs.com/downloads/AWD_HuracanR8_1-18-1.enc
1.21 Firmware
Changes since 1.18
V1.19 Output Testing added
Firmware Version 1.21 - www.syvecs.com/downloads/AWD_HuracanR8_1-21-1.enc
1.21.2
Version 1.21.2 contains the following updates
Changes since 1.12.1
Receive of Snow Mode on Audi R8
Receive of Handbrake
Firmware Version 1.21 - www.syvecs.com/downloads/AWD_HuracanR8_1-21-2.enc
1.23 Firmware - X4
Changes since 1.21:
OLD BOARD - Firmware Version 1.23 - www.syvecs.com/downloads/AWD_HuracanR8_1-23-1.enc
NEW BOARD - Firmware Version 1.23 - www.syvecs.com/downloads/X4AWD_HuracanR8_1-23-1.enc
1.23.3
Changes since 1.23.1:
OLD BOARD - Firmware Version 1.23.3 - www.syvecs.com/downloads/AWD_HuracanR8_1-23-3.enc
NEW BOARD - Firmware Version 1.23.3 - www.syvecs.com/downloads/X4AWD_HuracanR8_1-23-3.enc
1.24
Changes since 1.23.3:
OLD BOARD - Firmware Version 1.24.4 - www.syvecs.com/downloads/AWD_HuracanR8_1-24-4.enc
NEW BOARD - Firmware Version 1.24.4 - www.syvecs.com/downloads/X4AWD_HuracanR8_1-24-4.enc
