Traction control
Jez
Horsham Developments
Contact:
Re: Traction control
Post by Jez »
Good innit :)
Wez
Santa's Little Helper
Post by Wez »
Jez wrote:Good innit :)
The fact it could deal with the motor in high boost, R888 tires and wet roads shocked me, what a noise as well 8-)
Dan
Post by Dan »
How is yours setup Wez? Is it using an ign retard only or is there some sort of fuel cut in there as well? Any EGT feedback built into it to limit the retard duration?
Dan
Wez
Post by Wez »
Dan wrote:How is yours setup Wez? Is it using an ign retard only or is there some sort of fuel cut in there as well? Any EGT feedback built into it to limit the retard duration?
Dan
It does use EGT feedback yes, but at the moment its based on fuel cut so not much coming into a affect, Ryan could add more info if you need it.
