S6 on evo 9 trigger question
KulinPapa
Contact:
Post by KulinPapa »
I'd like to ask if S6 could work on mitsubishi evo9 engine with the stock trigger system?
pavlo
Zen Performance
Re: S6 on evo 9 trigger question
Post by pavlo »
Yes it can, complete with MIVEC support
EVO9GT
Post by EVO9GT »
What values should be - Generic of Crank Teeth - Number of Crank Teeth - for evo9? Evo stock trigger 4-1. Values - 3 - not setup.
Syvecs Staff - Cleaner
Contact:
Post by pat »
It is not possible to run the 4G63 engine on the stock trigger wheel using the generic patterns because that wheel does not have any unique features in the pattern - that is to say that it doesn't have any missing or additional teeth that we can "key" off. In order to run the engine you'll need to use the MITSUBISHI EVO pattern option under Engine Configuration -> Crank and Cam Type. You will also need to set the Signal Trigger Edge for the Crank sensor to BOTH, and you should set the Cam (Phase) sensor to FALLING edge trigger. That should ensure the correct sequencing of edges and correcty pattern detection. If you want a better pattern then there are some after market 18-1 wheels out there that will allow the use of the generic patterns in the ECU and it will be possible to key off the crank such a wheel.
EVO9GT
Post by EVO9GT »
Thanks Pat!
