Hello
I'm in need of another 5v output for an oil pressure sensor.I've used the 2 available outputs already.
From what i understand i could use one the unused 5v ignition outputs. Is this correct?
thanks
phil
Additional 5v outputs for sensors
Re: Additional 5v outputs for sensors
You can attach multiple sensors to a single 5v reference output.
I wouldn't have thought using an ignition output was a good idea.
Ah great!
Thank you very much
Phil
Thank you very much
Phil
