extra egt
ford racing
extra egt
Post by ford racing »
hi is it possible to wire in 2 extra thermocouples to log 2 extra egt
Re: extra egt
S6 has one built-in EGT amp., S8 has 2.
To add more than that you'll need external EGT amplifiers that will provide a 0-5V output that the S6/S8 can read.
Re: extra egt
I used to have a link to a really cheap one, they dont seem to list them anymore. It was around $20. This appears to be same sort of thing at a cheap price
http://shop.vems.hu/catalog/amplifier-dsub9-p-129.html
More expensive options, 1 channel and up
http://thesensorconnection.com/egt-elec ... analog-out
http://thesensorconnection.com/egt-elec ... e-0-5-vdc-
http://www.exhaustgas.com/ProductDetail ... ID=&RepID=
ford racing
Re: extra egt
thanks for info ,can the inovate tc4 be used
Re: extra egt
Don't think so - that is for their "MTS" system so has a serial data I/O rather than 0-5V analogue, as far I can see.
Re: extra egt
TC-4 only transmits over the serial datastream.
It does not output any 0-5v voltage based on temperature, the sales blurb for it can be a little misleading. It does provide a 5v supply for powering other sensors though
ford racing
Re: extra egt
ok thanks again
