traction control setup
Gpro
Post by Gpro »
I am about to purchase a syvecs s6 gp ecu for a mkiv supra, I have been looking at the s6 pinout and see front left and rear left speed sensors but don't see any for the right front and right rear, How would i wire it up? also i assume i tap in to the abs ecu speed sensors correct?
Gpro
Re: traction control setup
Post by Gpro »
do i wire it up on 2 empty slots and tell it on io configuration which wire the front right and rear right abs is at?
pavlo
Zen Performance
Post by pavlo »
You will need to use analogue inputs 1-8 for measuring any frequency/speed/time like crank, cam or wheel speed.
From memory the Supra setup only has 2 inputs free that are not compatible with the OEM speed inputs so you will need to use a converter module to tap into the OEM ABS sensors as discussed here: viewtopic.php?f=6&t=553
Ryan will know more on the exact setup of the Supra harness.
Gpro
Post by Gpro »
Just confirmed it, i only need to use front left and rear left to get traction control to work on a supra.
Just a quick question without making a new thread what is CTL-XXX on scal io configuration?
"CTL-XXX" is a historic reference to something I have never worked out ans, as far as I know, is completely irrelevant lol. Ignore them :)
There is a cross reference of "AN" to the "AB/AV/AR/AU" naming on the Syvecs website here.
pavlo
Zen Performance
Post by pavlo »
ctl-xxx refers to the pin on the control board.
