hi there just wondering what pins to use on the s6gp to handle the a/c request
i have a blue/red wire from the a/c switch to turn on and a brown wire to go to the a/c clutch relay
many thanks rob
a/c request
Re: a/c request
You can assign the swith to any input, but you need to find out if the input goes high or low when switched, if you used AN05-AN08 you will be able to use any switch config. The clutch relay will need to be wired with one side of the coil to ignition switched +12v and the other to either a spare fuel or PWM (aux) output. The pins can be found in the wiring guide here: viewtopic.php?f=6&t=401
