unable to connect anymore ?
ScoobyDuck
Re: unable to connect anymore ?
Post by ScoobyDuck »
Yes, it sees the NIC in SNET.
Doesnt work in a VM on that machine either, so something with the actual NIC although it works fine as it should (i.e network etc)
There's not much point in a screen shot as it just says no ecu found, like you dont have the ign on.
Strangly it just stopped working. has always worked flawlessly before. Will try some more investigating some day soon as i REALLY need to get into the ecu!
Steve
Jolly Green Monster
Post by Jolly Green Monster »
has the cable been pulled?
seen one ecu where the cable got pulled and pulled the socket off the board...
ScoobyDuck
Simon,
nope, it works ok with an identical laptop with identical image of windows on it
Steve
