unable to connect anymore ?
Tweaks
Post by Tweaks »
hi
hoping someone on here can help me get back 'online' with my ecu.
originally everything was working as it should and loaded on a start up file that Simon sent me.
Simon then came out to map the car and everything was fine,now i've tried getting into scal and it won't connect ? keeps bringing up unidentified network and in public.
i've tried a different cable,restarting laptop and even reinstalling the software but the same thing occurs,i cannot understand why it would work perfectly and then not identify the ecu/network.
any help would be greatly appreciated.
many thanks
Tim
p.s win7
jura11
Re: unable to connect anymore ?
Post by jura11 »
Hi Tim
Assume you have W7 64bit,if yes please install different version of Syvecs Suite
I've before similar problem with my brother Laptop
Have look on this thread
http://www.syvecs.co.uk/forum/viewtopic.php?f=8&t=222
Jura
Tweaks
Post by Tweaks »
Hi Jura
i'm on 32 bit system fella,as stated it was working perfectly well last time i had the laptop out in the car.
i'll have a look through the link all the same though.
thanks
Tim
jura11
Post by jura11 »
Hi Tim
Please check if SNetServer.exe is working(just have look under Process in the Task Manager)...
Second bit,do you try connect to your Syvecs with opened CAL which send you Simon?
If yes Syvecs will NOT connect if you have opened CAL(or CAL which you opened before you are want to connect to ECU)
Jura
Tweaks
Post by Tweaks »
Hi Jura
i'll check the process tomorrow night after work but it seems to be a problem with not making a network connection.
have tried plugging cable in then opening scal
opening scal then plugging in cable
opening a cal file when plugged in
starting a new cal when plugged in
just won't seem to work online ?
works perfectly well offline.
many thanks
Tim
jura11
Post by jura11 »
Hi Tim
Try log off on your Windows or try restart the laptop and after that try again connect Syvecs
Jura
Wez
Santa's Little Helper
Post by Wez »
I have noticed on some machines using Windows 7 (32 or 64bit) that by default the network driver has the option, allow to sleep when not connected.
As the ECU is not seen by windows as a valid connection it puts the network adapter to sleep, just disable this feature under network adapter settings :)
ScoobyDuck
Post by ScoobyDuck »
I have the same issue with a W7 x64. have done all the above and it wont connect. just wont find the ECU.
Have tried an identical machine and it works 1st time.
reloaded nic drivers etc etc.
SNET is just not picking up the ECU.
really annoying.
Steve
Wez
Post by Wez »
Is SNET seeing the network card?
Can you post a screenshot?
jura11
Post by jura11 »
We're have before similar problem on W7 64bit,in our case I've tried few versions of the Syvecs Suite and seems 2.11.18 working on our one
Jura
