TPS Values
TPS Values
Been playing with data logging and starting to try and get my head around the Syvecs software to see if I can trouble shoot a couple of things. What values would be normal for the TPS readings, mine varies from 2.6 to 3.2 when closed (well foot off pedal) does this look like a 'normal' reading or should it read 0?
Re: TPS Values
Mine reads 2-3% so that sounds normal. WOT is about 90%.
Re: TPS Values
Thanks now to make sense of this evening logs!
