Syvecs I/O Configuration Pin Assignments
jinglezdj
Post by jinglezdj »
Hi Chaps,
I've had a good search around the forum and on the internet to find this information but so far I can't seem to find what I am looking for. Hopefully somebody can help here.
Is there a document that shows what each pin assignment is for with a standard ECU install? IE. If I put a V3/4 Syvecs into a V3/4 car what would be the standard pin assignments for the crank/cam sensors etc?
Thanks for any help offered,
Keith
pavlo
Zen Performance
Re: Syvecs I/O Configuration Pin Assignments
Post by pavlo »
All the info is on this forum.
pavlo
Zen Performance
Post by pavlo »
jinglezdj
Post by jinglezdj »
Hi,
Thanks for the info, I have seen that information but I could see how that transfers over to this:
When I turn over the engine I get this:
Does anybody have any idea why I can't get Sync 720?
Thanks,
ScoobyDuck
Post by ScoobyDuck »
It may be that the IO's for the cam/crank have been swapped (i.e. if you've had an APEXI ecu previously?). In which case, try swapping the inputs over in IO config.
You might get a better idea of whats happening under DEVICE/VIEW SYSC LOG
Steve
jinglezdj
Post by jinglezdj »
Sorted it, thanks Steve.
That was the problem,
ScoobyDuck
you're welcome & good luck.
