Best way to "cut" revs for idle with throttle jacked open?
For Subaru Technical Chat
EMS
Post by EMS »
As topic title. We need jacked open throttle for decent ALS, but idle is too high. (of course) Is there a decent way to introduce some sort of rev-limit for idle?
Jasper K
Re: Best way to "cut" revs for idle with throttle jacked open?
Post by Jasper K »
Hi Mark,
Shouldn't you be using Fuel Cut to keep revs under control?
On the other hand..... If revs are too low so is airflow through the engine and that means the turbo is not going to spool really good anyways. In my opinion it's always a trade off. I would think introducing Fuel Cut to keep revs under control seems like a good way.
TBH. What else would a "Rev-Limiter" normally do?....... Cut fuel(or spark but that wouldn't be very wise) ;-)
Jasper.
EMS
Post by EMS »
Hi Jasper,
Perhaps I wasn't completely clear. But I don't mean the control of RPM with ALS on, but with ALS off! With ALS on the ignition retard will drop RPM, but if I jack the throttle open for good ALS the revs go through the roof with "normal" ignition timing...
Mark.
Dont jack open the throttle until ALS is active then ? Dont the two happen together ?
Jasper K
Post by Jasper K »
Hi Mark,
If I understand you correctly it seems that you are running a Cable actuated Throttle. You are jacking it open continuously to allow for ALS when activated but this jacked open throttle situation is more or less fixed so gives high revs with "normal" timing. Is this correct?
If this is the case I would strongly suggest to use a Throttle jacker which is only operating when the ALS is active and will not have a jacked throttle when ALS is deactivated. If this is not an option than perhaps a large PWM actuated Bypass Valve would be also a good option. You can keep the throttle as you would normally and activate the Bypass valve as soon as ALS is activated to let a lot of air go past the Throttle body directly into the intake manifold.
Another option would be to fit a DBW throttle body and call it a day :D
Jasper.
EMS
Post by EMS »
Yes, of course cable operated throttle. (otherwise I wouldn't have asked...) ;) I want to open the throttle more by adjusting the screw which sets the throttle rest position. In the Motec you can set a idle rev limit for such setups. In all of the older group N rallycars (no DBW) you need to setup ALS like this. It's not allowed to add by-pass valves or DBW throttle.
Syvecs Staff - Cleaner
Post by pat »
Just a quick note....
What you want is AntiLag System -> Off Calibration, where you will find fuel cut and multiplier (if memory serves) to be applied when ALS is *off*, which is designed for just this purpose :)
EMS
Post by EMS »
PERFECT, just what I was looking for!
Thanks Pat!
Jasper K
Post by Jasper K »
Awesome! Something new learnt again as well.
EMS
Post by EMS »
It's the only possible way to get more air in the engine, without being illegal. Finshed the car today and it worked fine with the fuel cut function to have idle speed under control. It's a bit shitty to cruise at low speeds, as you are cruising with something between 1 and 3% TPS. And I need to have quite a bit of fuel cut below 1% TPS to control the revs. But if you drive the car on a rally stage it's perfectly fine! 8-)
