Latest Base Map
Technical Help / Firmwares for the Nissan R35GTR Awd Controller
Ryan.g
Syvecs Staff - Caretaker
Latest Base Map
Post by Ryan.g »
The latest Nissan R35GTR AWD Base map which matches the latest firmware can be found below in Attachments
AwdBase_GTR 1.14.SC
(37.21 KiB) Downloaded 2285 times
Ryan.g
1.15
Post by Ryan.g »
1.15 Firmware Latest base map
AwdBase_GTR 1.15.SC
(38.8 KiB) Downloaded 2279 times
Ryan.g
1.18
Post by Ryan.g »
AwdBase_GTR 1.18.SC
(42.89 KiB) Downloaded 2169 times
Ryan.g
1.21 Base Map
Post by Ryan.g »
For use with 1.21 Firmware
AwdBase_GTR 1.21.SC
(46.26 KiB) Downloaded 2247 times
Ryan.g
1.23 Base Maps
Post by Ryan.g »
For use with 1.23 Firmwares
AwdBase_GTR 1.23.SC
(51.46 KiB) Downloaded 2109 times
AwdBase_GTR 1.23 X4.SC
(51.46 KiB) Downloaded 2097 times
Ryan.g
1.24 Base Maps
Post by Ryan.g »
For use with 1.24 Firmwares
AwdBase_GTR 1.24.SC
(55.83 KiB) Downloaded 2082 times
AwdBase_GTR 1.24 X4.SC
(55.78 KiB) Downloaded 2105 times
Ryan.g
1.25
Post by Ryan.g »
AwdBase_GTR 1.25 X4.SC
(61.05 KiB) Downloaded 2077 times
Ryan.g
Re: Latest Base Map
Post by Ryan.g »
For use with 1.27 Firmwares
AwdBase_GTR 1.27.SC
(66.84 KiB) Downloaded 221 times
AwdBase_GTR 1.27 X4.SC
(66.87 KiB) Downloaded 198 times
Ryan.g
Re: Latest Base Map
Post by Ryan.g »
For use with 1.28 Firmwares
AwdBase_GTR 1.28 X4.SC
(72.44 KiB) Downloaded 6 times
Ryan.g
Re: Latest Base Map
Post by Ryan.g »
1.29 Base map
AwdBase_GTR 1.29 X4.SC
(72.89 KiB) Downloaded 5 times
