Latest Base Map
Technical Help / Firmwares for the Audi R8 Gen2 and Lamborghini Huracan Awd Controllers
Ryan.g
Syvecs Staff - Caretaker
Latest Base Map
Post by Ryan.g »
The latest Huracan/R8 AWD Base map which matches the latest firmware can be found below in Attachments
AwdBase_HuracanR8 1.14.SC
(37.21 KiB) Downloaded 771 times
Ryan.g
Re: Latest Base Map
Post by Ryan.g »
1.15 Firmware Base Map
AwdBase_HuracanR8 1.15.SC
(41.62 KiB) Downloaded 661 times
Ryan.g
1.18
Post by Ryan.g »
AwdBase_HuracanR8 1.18.SC
(42.89 KiB) Downloaded 648 times
Ryan.g
1.21 Base Map
Post by Ryan.g »
For use with 1.21 Firmware
AwdBase_HuracanR8 1.21.SC
(48.05 KiB) Downloaded 638 times
Ryan.g
1.23 Base Maps
Post by Ryan.g »
For use with 1.23 Firmwares
AwdBase_HuracanR8 1.23 X4.SC
(51.46 KiB) Downloaded 559 times
AwdBase_HuracanR8 1.23.SC
(51.46 KiB) Downloaded 614 times
Ryan.g
1.24 Base Maps
Post by Ryan.g »
For use with 1.24 Firmwares
AwdBase_HuracanR8 1.24 X4.SC
(55.78 KiB) Downloaded 582 times
AwdBase_HuracanR8 1.24.SC
(55.83 KiB) Downloaded 559 times
Ryan.g
1.25
Post by Ryan.g »
AwdBase_HuracanR8 1.25 X4.SC
(61.05 KiB) Downloaded 549 times
Ryan.g
Re: Latest Base Map
Post by Ryan.g »
For use with 1.27 Firmwares
AwdBase_HuracanR8 1.27 X4.SC
(66.87 KiB) Downloaded 150 times
AwdBase_HuracanR8 1.27.SC
(66.84 KiB) Downloaded 146 times
Ryan.g
Re: Latest Base Map
Post by Ryan.g »
For use with 1.28 Firmwares
AwdBase_HuracanR8 1.28 X4.SC
(72.44 KiB) Not downloaded yet
