Hi all,
I am currently running a motorcycle engine (so N is a half shift between 1 and 2) with pneumatic shifting. I understand that Syvecs supports half shifts to and from N if a clutch switch is depressed and the gear position reads either 1, N or 2. However, my engine does not have a dedicated gear position sensor; I will be using wheel speed and gear ratios to calculate it within Syvecs.
My worry is that if the driver has the physical clutch depressed then the ECU will not know the gear position and thus won't half shift to N. Does the gear position default to N if the wheels are not spinning (if clutch is depressed while in gear), and with my current configuration is there a way to successfully half shift? Thanks.
Half Shift with Wheel Speed Gear Position
Jump to
- ↳ General Syvecs Chat
- ↳ S6 GP/PnP Technical
- ↳ S6-I / S6Plus Technical
- ↳ S7-I / S7Plus Technical
- ↳ S8 Technical
- ↳ S12 Technical
- ↳ Syvecs Bluetooth Module
- ↳ Software
- ↳ Calibrations
- ↳ Technical Deposit
- ↳ Projects
- General Technical Forums
- ↳ Subaru
- ↳ Mitsubishi
- ↳ Toyota
- ↳ Nissan
- ↳ Porsche
- ↳ Dyno Talk
- ↳ Track Days
- ↳ VAG Technical
- Expanders
- ↳ X10 (Legacy - Gen1)
- ↳ X10 Gen2 Expander
- ↳ X20L Gen2
- ↳ X4 Gen2
- ↳ OEX - Oem Ecu eXpander
- Syvecs AWD Modules
- ↳ General Questions
- ↳ Porsche 991.1 / 991.2
- ↳ Porsche 997.1 / 997.2
- ↳ Huracan / R8
- ↳ Nissan R35GTR
- ↳ Infiniti Q60
- ↳ Yaris GR
- ↳ CorollaGR
- ↳ Generic AWD Module
- ↳ Syvecs KT8
- ↳ KT8 Rev3 Standalone
- ↳ Syvecs Wifi Module
- ↳ Syvecs WMI Module
- ↳ Syvecs DI12
- ↳ Syvecs Lam2CAN
- Syvecs Dashes
- ↳ Syvecs TinyDash
- ↳ Syvecs D5 Dash
- Enhancements
- ↳ Feature Requests
- ↳ Request for Comments
- JT Innovations
- ↳ Toucan Display
- ↳ General
- Feedback
- ↳ Website feedback
