connections
Posted: Wed Feb 01, 2017 3:15 pm
				hi newbie to these ecus and expanders .
need to use i/o expander and wondered what were the best input and outputs to use
i have 10 inputs
front wheel sensor n/s
front wheel sensor o/s
rear wheel sensor n/s
rear wheel sensor o/s
paddle shift up
paddle shift down
cal 1
cal 2
cal 3
air pressure
outputs
up shift
down shift
compressor start
can 2h [pin28]
can 2l [pin29]
also i take it you use a piggy back off the 12 v [pin 34 ]for wheel sensors and ground
[ an ground ]pin 24 and control for paddles shift.
and do i use 5v output on pin 25 for cal switches.
regards pete
i have 10 inputs
paddle shift up
paddle shift down
cal 1
cal 2
cal 3
air pressure
outputs
up shift
down shift
compressor start
can 2h [pin28]
can 2l [pin29]
regards pete
