Page 28 of 29
Posted: Tue Mar 26, 2024 8:57 pm
by Jackstrath
Yeh they are,
So gear shift manual blip request is - BLIP_SLOT / / Slave an21
Gear shift manual cut request is - GEARCUT_SLOT / /Slave an25
Then there’s the brake pressure front - BRAKEP_SLOT / / Slave an19
There’s a few I don’t use but that’s the main ones
Posted: Tue Mar 26, 2024 9:59 pm
When you compare them to what's happening at shifts, the gear cut and blip do definitely occur at a shift point when you view the slaveAN values.
So they are being seen
Posted: Tue Mar 26, 2024 10:18 pm
by Jackstrath
But it looks (for the blip anyway) to be occurring after the gear has been selected and not during or before. Still doesn’t explain why I’m seeing no gear blip request tho?
Posted: Tue Mar 26, 2024 10:24 pm
their names are not the standard names for shifts and cuts etc, so they must be using the custom tables to do something ?
No idea really.
Posted: Tue Mar 26, 2024 11:57 pm
by Jackstrath
Well beek just got back to me. Interesting it looks like they are actually active on? I never looked to see if the requests had came back? Man this is weird?
Posted: Fri Mar 29, 2024 6:15 pm
by Jackstrath
So, iv figured out why the blips and cuts have started working (and wow what a difference thats made to the box downshifting)
So i changed my switch panel up and moved things about, but i then fitted the cal select switch upside down..... so when i got in the car i just set it to cal1 but turns out that was cal8.... now cal 7 has basically the safteys turned off so if i hit a sensor fail mid race i can cancel it and continue. Im wondering if cal 8 has something activated that allows blips/cuts to work and cal 1 doesn't! i have had a look but i cant see anything obvious under the calibration switch tab?
Posted: Sun Apr 21, 2024 11:51 pm
by Jackstrath
So just seen the 1.75 update, im not sure how that works with my custom firmware from beek so iv sent an email.
One thing i did do over the weekend was add a single rear wheel speed sensor, idea is to run TC on select Cal's. Watched the help video, They use all 4 sensors, does the system still work with just 1 rear speed sensor?
Posted: Mon Apr 22, 2024 7:23 am
Just set your undriven to whatever wheel, and driven speed to whatever relevant wheels
Posted: Wed May 01, 2024 8:12 pm
by Jackstrath
Ok so successful weekend with the TC set up, got it working pretty good where it limits wheel spin but doesn't feel intrusive, sure it could prob be better but for now im happy with that.
One thing i cant seem to shake is a error message for the logbook, iv tryed changing things, making sure the log book is set to the right version and clearing the log book but i cant seems to get this message to disappear? Any ideas?
Posted: Wed May 01, 2024 8:24 pm
That happens sometimes when changing firmwares.
Damned if I can remember specific route to clearing it, but need to do as it says really by clearing the logbook. I think Device/Logbook ?
Or maybe clear the datalogs in SData ?
