hey all, would be good to have an input for a clutch input shaft rpm sensor and tail-shaft speed to map a run to help with slipper/with lock up solenoid, clutch settings in a drag car scenario
or to the point some dedicated drag racing strategies to help with logging and clutch/traction control settings
cheers.
gearbox input rpm for slipper clutch
Re: gearbox input rpm for slipper clutch
For logging, the latest firmware did give you the option of custom sensor inputs, so that would cover that aspect.
These can be in turn used for controls too via 2D/3D tables, but I havent used any of it yet.
https://www.youtube.com/watch?v=IVIdYESOuOQ
