WARNING - 12 Pin AUX Connector
Posted: Thu Jan 22, 2015 12:29 pm
There has recently been some confusion regarding the 12 pin AUX connector - it is present on both the PnP carriers and also on the kits. The standard pinout is the PnP Carrier one which may be found here, whilst the loom adapter kits use a non-standard pinout and come with their own pinout sheet. Please use the standard pinout when wiring to PnP carriers, and use the pinout supplied with your kit, if you are installing a kit.
