Generate excel compatible CSV file from logger
I see we can export via a text file but this means fiddling about with a text editor to convert it to excel. Is it possible to convert it straight to a CSV file format that we can open in straight from excel? Thanks.
Re: Generate excel compatible CSV file from logger
I don't know what you're missing but you just use "Export To" choose "Text File (CSV)", select 20hz and you're done. I've just done it and opened it straight away in Excel 2007 no problem.
If your software doesn't have this, DOWNLOAD THE LATEST VERSION!
