Tacho Output Problems
Posted: Mon Jan 30, 2012 8:49 pm
I'm having issues with the tacho output from the S8C to my tachometer. The Tachometer used to work directly from a ground on one of the coilpacks. I have since done an engine swap and was hoping to drive it directly from the ECU.
Symptoms: After 4k rpm the needle falls on the gauge back to 0 and then behaves erratically.
Attempted Solutions: I have tried no pullup, 10k and 1k pullups. The 1k pullup improved the output marginally. I have spoken to the gauge manufacturer and they have said that they sometimes require a 1k pullup, but apart from that they do not have problems with their gauges being driven direct from the ECU.
Documentation: http://www.etbinstruments.com/ETB_Gauge ... ometer.pdf
I currently have the pin IO set to an injector output. Should I try an ignition output? Smaller ohm resistor? Unfortunately I can't run from the coilpack as I require 1 pulse per rev.
Any ideas?
Any ideas?
