Version 1.128 Adds the following updates:
// 1.116 - CX29 Ecutek Code
// 1.117 - Change Light Strategy, More CM Maps,
// 1.118 - Added Change Light Timeout and BMW F/G Series / Supra UpShift with Change Light, CX29 Mode Select from CalSelect
// 1.118 - Sync State Flag Sent in CX29 16bit Tag0
// 1.119 - Sync not 720 in Ecutek or MHD will send Error Crank flag
// 1.119 - Added Ecutek legacy adjustable ID's and Transmit rates
// 1.119 - Added Ecutek Aux Selection item
// 1.120 - Fan3 Duty Enable Change
// 1.120.3 - Change ECUtek RX and TX ID Default values
// 1.121 - Ecutek CX29 Trigger logics
// 1.122 - Fuel Pump Enable, Customisation option
// 1.123 - Short Tooth Gap disable option for noisy looms
// 1.123.3 - Changes to Datalog - INTERNAL - Moved Datalog() out of 250us to Interupt
// 1.124 - Exhaust Pressure to 10bar, Fuel Comp Error Timeout, Sensor Warning Error Flag
// 1.125 - Error Flag System, diagSensErr, diagSensor, diagSensType, Added Gear and CalSelect in Custom axis maps
// 1.125 - Implementing SyncLog
// 1.125 - CANFD support in Generic Transmit
// 1.126 - SyncLog Feature added, when enabled the datalogging will only log sync data and items
// 1.127 - Crank Filter
// 1.128 - Edited CalUp Down Help, Bugfix with CalUpDown and Datastream Slot limited to 10, rep fix
// 1.128.2 - Endianess option not working on Generic Transmit, change CAN Transmit not to transmit 0x400 as default
// 1.128.4 - Fuel Pump ON/OFF Logic fix
Please ensure you are using the Latest Ssuite software which has USB support -
http://www.syvecs.com/forum/viewtopic.php?f=8&t=122
Help on updating the firmware can found via -
https://www.syvecs.com/downloads/Syvecs_Updater.pdf
Firmware Version 1.128 -
https://www.syvecs.com/downloads/X20OEX_1.128.4.enc
