				Synchronous hpfp control
				Posted: Sat Jun 17, 2023 1:26 pm
				by Gaposgarage
				As of now the n54 has a async pump but its contoled with a clpwm generic output.
I recently got the s55 hpfp that has a gear driven drive for the pumps cam but, it doesn't turn at a 1:1 or a 2:1 ratio.
Looking in scal it appears on sight that the cam setup is on a 0 to 720 so i assume the hpfp cam needs 720 sync?
I don't know if this is an issue?? This is a huge learning curve for me i must admit.
Hoping someone can help put me in the right direction
				Re: Synchronous hpfp control
				Posted: Sun Dec 31, 2023 6:27 am
				by beetos
				Hi
Curious to know how you went. My N54 still uses the async pump but I am mapping much differently to the base map and it works good now. Are you converting yours to a sync pump ?
				Posted: Mon Feb 12, 2024 3:38 am
				by Gaposgarage
				i ended up going di delete. ive had it with piezo injectors and almost finished with my n51 head swap, just waiting on cometic to finish the head gasket
i considered using an n55 head and seloniod di but once i got the car turned up i started destroying gs6-53bz gear boxes. i think theres better places to spend the money for now. (didnt sell the s55 pumps yet at least
some issues i think could need resolutions:
the vac pump sproket drives the hpfp lift cam. its not syncronous with the crank. cant recal exactly what it was but i think that sproket needs 3 more teeth to pull it off and then the oil pump timing chain would need lengthened. cant speak on the chain module but it could need attention aswell.
				Posted: Wed Nov 27, 2024 6:55 am
				by otis
				Gaposgarage wrote: Sat Jun 17, 2023 1:26 pm
Stickman Hook
You're tackling an interesting and complex upgrade by swapping the N54’s asynchronous fuel pump (HPFP) with the gear-driven HPFP from the S55. Let’s break down your challenge and provide clarity on how to move forward.
