I started setting up the WMI controller. My goal is that With Cal1 the injection is off, then Cal2 and Cal3 have individual settings (setting up on 991 which has 3 cal settings).
I have the duty set as zero for Cal1 (not injecting). However I can’t figure out how to control the pump separately for each calibration. If I set a basic activation strategy (rpm or map) then I believe the pump will still activate on Cal1.
I’ve looked at PMW Pump Control (seems complicated for what I’m after) and setting the pressure above max pressure for the pump and then using EnableWMI threshold to turn on the pump when the solenoid duty exceeds the threshold. But I am not sure if this is how it works (instructions aren’t clear)
Help!! Maybe I’m over complicating this (ie the pump runs whenever solenoid duty is greater than 0), but I can’t quite figure this out.
						WMI Pump Control
The Syvecs WMI controller is a compact but very powerful unit for controlling a complete Water Injection electronics system, safely and correctly.
				Jump to
 - ↳ General Syvecs Chat
 - ↳ S6 GP/PnP Technical
 - ↳ S6-I / S6Plus Technical
 - ↳ S7-I / S7Plus Technical
 - ↳ S8 Technical
 - ↳ S12 Technical
 - ↳ Syvecs Bluetooth Module
 - ↳ Software
 - ↳ Calibrations
 - ↳ Technical Deposit
 - ↳ Projects
 - General Technical Forums
 - ↳ Subaru
 - ↳ Mitsubishi
 - ↳ Toyota
 - ↳ Nissan
 - ↳ Porsche
 - ↳ Dyno Talk
 - ↳ Track Days
 - ↳ VAG Technical
 - Expanders
 - ↳ X10 (Legacy - Gen1)
 - ↳ X10 Gen2 Expander
 - ↳ X20L Gen2
 - ↳ X4 Gen2
 - ↳ OEX - Oem Ecu eXpander
 - Syvecs AWD Modules
 - ↳ General Questions
 - ↳ Porsche 991.1 / 991.2
 - ↳ Porsche 997.1 / 997.2
 - ↳ Huracan / R8
 - ↳ Nissan R35GTR
 - ↳ Infiniti Q60
 - ↳ Yaris GR Gen1
 - ↳ CorollaGR / Yaris GR Gen2
 - ↳ Generic AWD Module
 - ↳ Syvecs KT8
 - ↳ KT8 Rev3 Standalone
 - ↳ Syvecs Wifi Module
 - ↳ Syvecs WMI Module
 - ↳ Syvecs DI12
 - ↳ Syvecs Lam2CAN
 - Syvecs Dashes
 - ↳ Syvecs TinyDash
 - ↳ Syvecs D5 Dash
 - Enhancements
 - ↳ Feature Requests
 - ↳ Request for Comments
 - JT Innovations
 - ↳ Toucan Display
 - ↳ General
 - Feedback
 - ↳ Website feedback
