Latest Firmware Releases
Technical Help / Firmwares for the Yaris GR Awd Controllers
Locked
Changes since 1.18
V1.19 Output Testing added
V1.21 Output mode on changelight output to Lowside, Yaris HandBrake disable test mode light on dash in Burnout, Gear displayed in breakpoint, MAP1 Multiplier, post shift Multiplier to help stop spin after drivetrain torque change
Firmware Version 1.21 - www.syvecs.com/downloads/AWD_Yaris_1-21-1.enc
1.23 Firmware - X4
Changes since 1.21:
V1.22 - Adjustable the Yaris display bars vs duty to match more OEM, SnowMode on the R35GTR selects AwdSel3
V1.23 - Added Gear Duty Multiplier
OLD BOARD - Firmware Version 1.23 - www.syvecs.com/downloads/AWD_Yaris_1-23-1.enc
NEW BOARD - Firmware Version 1.23 - www.syvecs.com/downloads/X4AWD_Yaris_1-23-1.enc
1.23.3
Changes since 1.23.1:
*Bugfix with AwdSel and key on
OLD BOARD - Firmware Version 1.23.3 - www.syvecs.com/downloads/AWD_Yaris_1-23-3.enc
NEW BOARD - Firmware Version 1.23.3 - www.syvecs.com/downloads/X4AWD_Yaris_1-23-3.enc
1.24
Changes since 1.23.3:
OLD BOARD - Firmware Version 1.24.4 - www.syvecs.com/downloads/AWD_Yaris_1-24-4.enc
NEW BOARD - Firmware Version 1.24.4 - www.syvecs.com/downloads/X4AWD_Yaris_1-24-4.enc
1.25
Changes since 1.24.4:
OLD BOARD - Firmware Version 1.25.1 - www.syvecs.com/downloads/AWD_Yaris_1-25-1.enc
NEW BOARD - Firmware Version 1.25.1 - www.syvecs.com/downloads/X4AWD_Yaris_1-25-1.enc
Re: Latest Firmware Releases
Changes since 1.25.1:
* Added LatG Duty Adjustment
OLD BOARD - Firmware Version 1.27.1 - https://www.syvecs.com/downloads/AWD_Yaris_1-27-1.enc
NEW BOARD - Firmware Version 1.27.1 - https://www.syvecs.com/downloads/X4AWD_Yaris_1-27-1.enc
1.29 Firmware Release
Changes since 1.27.1:
* USB Datalogging
* Added Launch Mode
OLD BOARD - Firmware Version 1.29.1 - https://www.syvecs.com/downloads/AWD_Yaris_1-29-1.enc
NEW BOARD - Firmware Version 1.29.1 - https://www.syvecs.com/downloads/X4AWD_Yaris_1-29-1.enc
Changes since 1.29.1:
* Enable Load for Steering Angle Multiplier
* Option for AN1 to be BurnOut Switch or TransferCase Temp
* Transfer Case Temp Linearization and Limp
Firmware Version 1.34 - https://www.syvecs.com/downloads/X4AWD_Yaris_1-34-2.enc
Changes since 1.34.1:
* Added AWD Temp Diag CAN Stream for CANCHECKED Dash
Firmware Version 1.35 - https://www.syvecs.com/downloads/X4AWD_Yaris_1-35-2.enc
Locked
