Latest Firmware Releases
Posted: Mon Sep 27, 2021 12:25 pm
by Ryan.g
Version 1.15 contains the following updates
*Change Light Output Pin (HBR4)
*Drive ratio calculation for Gear detection on Manual Trans cars
*Enable Gear Detection from Drive Ratio option
*Change Light Min Speed
*Change Light RPM
*Change Light Min Tps
Please ensure you are using the Latest Ssuite software which has USB support -
http://www.syvecs.com/forum/viewtopic.php?f=8&t=122
Help on updating the firmware can found in the via this YouTube Help video -
https://www.youtube.com/watch?v=RuXkm_9gBRU
Firmware Version 1.15.2 -
www.syvecs.com/downloads/AWD_Q60.enc
1.18 Firmware
Posted: Tue Oct 12, 2021 8:43 am
by Ryan.g
Changes since 1.15
1.18 - Added simple Map locking and Restriction option. - Press
C,
F inside a map
Firmware Version 1.18 -
www.syvecs.com/downloads/AWD_Q60_1-18-1.enc
1.21 Firmware
Posted: Thu Nov 04, 2021 5:48 am
by Ryan.g
Changes since 1.18
V1.19 Output Testing added
Firmware Version 1.21 -
www.syvecs.com/downloads/AWD_Q60_1-21-1.enc
1.23 Firmware - X4
Posted: Wed Jul 13, 2022 2:16 pm
by Ryan.g
Changes since 1.21:
OLD BOARD - Firmware Version 1.23 -
www.syvecs.com/downloads/AWD_Q60_1-23-1.enc
NEW BOARD - Firmware Version 1.23 -
www.syvecs.com/downloads/X4AWD_Q60_1-23-1.enc
Re: Latest Firmware Releases
Posted: Thu Aug 11, 2022 9:17 am
by Ryan.g
Changes since 1.23.1:
OLD BOARD - Firmware Version 1.23.3 -
www.syvecs.com/downloads/AWD_Q60_1-23-3.enc
NEW BOARD - Firmware Version 1.23.3 -
www.syvecs.com/downloads/X4AWD_Q60_1-23-3.enc
1.24
Posted: Fri Nov 25, 2022 12:10 pm
by Ryan.g
Changes since 1.23.3:
OLD BOARD - Firmware Version 1.24.4 -
www.syvecs.com/downloads/AWD_Q60_1-24-4.enc
NEW BOARD - Firmware Version 1.24.4 -
www.syvecs.com/downloads/X4AWD_Q60_1-24-4.enc
1.25
Posted: Fri Apr 07, 2023 6:58 pm
by Ryan.g
Changes since 1.24.4:
OLD BOARD - Firmware Version 1.25.1 -
www.syvecs.com/downloads/AWD_Q60_1-25-1.enc
NEW BOARD - Firmware Version 1.25.1 -
www.syvecs.com/downloads/X4AWD_Q60_1-25-1.enc
Posted: Fri Dec 15, 2023 5:19 am
by Ryan.g
Changes since 1.25.1:
* Added LatG Duty Adjustment
OLD BOARD - Firmware Version 1.27.1 -
www.syvecs.com/downloads/AWD_Q60_1-27-1.enc
NEW BOARD - Firmware Version 1.27.1 -
www.syvecs.com/downloads/X4AWD_Q60_1-27-1.enc
1.29 Firmware Release
Posted: Mon Apr 15, 2024 3:06 pm
by Ryan.g
Changes since 1.27.1:
* USB Datalogging
* Programming Fix
OLD BOARD - Firmware Version 1.29.1 -
https://www.syvecs.com/downloads/AWD_Q60_1-29-1.enc
NEW BOARD - Firmware Version 1.29.1 -
https://www.syvecs.com/downloads/X4AWD_Q60_1-29-1.enc
