Slave Comms errors
Posted: Sun Nov 29, 2020 4:28 am
				Hello,
I have an X10 on a S8 with a combination temperature & pressure sensor monitoring intercooler inlet temp & pressure. I continually get a Slave Comms error for both sensors under ECU errors even though both sensors are reading correct.
Any suggestions on how to stop these?
Also, is there a way to do a resistive output for a resistor type oil pressure gauge? The stock gauge is a resistive gauge and the stock pressure sender did not read the pressure range needed. I have a 10 bar, 5v sensor straight to the S8 but would like to do an output to the stock gauge to eliminate a gauge warning error on the stock dash. Would prefer to not run 2 pressure sensors.
Thank you!
Thank you!
