AVCS not working?
Re: AVCS not working?
SB560 is perfect. But I can't tell from that if you've wired it the right way round.
Thanks Tim.
Yellow wire(Blue stripped yellow) is 12v and cathode is connected to it.
Grey wire(blue) goes to ecu FUEL6 and anode.
I will try output testing mode without shottky to see the voltage again
I have found that I had accidently cutted ignition live 12V source wire that goes to DCCD & AVCS solenoids.
All sorted now.
All sorted now.
