running rich when getting off the gas pedal
I have a issue when in closed loop and driving i sit in the CCL afr area of 14 as chosen in the map, but when I take my foot off the pedal the afr will go to 9, before it settles back to 14, I am having troubles in finding the correct table to lean it out.
Re: running rich when getting off the gas pedal
Are you meaning when fully off the pedal, ie overrun scenario ?
Or gently downhill or something ?
For most part just look at the fuel table to see which load cells you are in and may need amended.
Or if overrun fuel cut is active....then whilst it is active AFR's should go lean until fuel is restored.
Yes when fully off the pedal,
I am having a trouble setting up activating it as the overrun is still putting in fuel.
