Version 1.107 is the first release of the OEX Firmware
Help on updating the firmware can found via - https://www.syvecs.com/downloads/Syvecs_Updater.pdf
Firmware Version 1.107 - www.syvecs.com/downloads/X20OEX_1.107.1.enc
Latest Firmware Releases
Re: Latest Firmware Releases
Version 1.114 Adds the following updates:
// 1.108 - Added Bmw and Supra CAN, Added Enable for 29bit in GenericRX
// 1.109 - Added Enable RPM and Tps for External WG, Fixed RPM in Focus RS Mk2, Fixed Wheel Speeds in BMW2020
// 1.109.2 - Sensor filtering tweak
// 1.110 - Added OBD2 TX Options, Coolant Pressure limp and maps
// 1.110.2 - Output Test fix, 20, 40, 60, 80% issue
// 1.111 - Added Generic TX CAN Frames
// 1.111 - TinyDash CAN Option
// 1.112 - Change User Rename items to be more flexible
// 1.113 - WG Turbo Speed sensors added and R35GTR Custom CAN Transmit waits for RPM
// 1.114 - Turbo Speed Control in WG Strategies
// 1.114.2 - Add option for SyncState to be set from GenRX or ICan sensors if no Crank Pin is assigned, so strategies like fuel pump work
Firmware Version 1.114 - www.syvecs.com/downloads/X20OEX_1.114.2.enc
Version 1.115 Adds the following updates:
// 1.114.3 - Sensor Filtering wrong for LAM1 and LAM2 as different REP
// 1.115 - Updated Help for Crank and Cam and Fixed so AN8 + can be used for Crank and Cam
// 1.15.2 - Programming Code adjustment
Firmware Version 1.115 - www.syvecs.com/downloads/X20OEX_1.115.2.enc
Version 1.128 Adds the following updates:
// 1.116 - CX29 Ecutek Code
// 1.117 - Change Light Strategy, More CM Maps,
// 1.118 - Added Change Light Timeout and BMW F/G Series / Supra UpShift with Change Light, CX29 Mode Select from CalSelect
// 1.118 - Sync State Flag Sent in CX29 16bit Tag0
// 1.119 - Sync not 720 in Ecutek or MHD will send Error Crank flag
// 1.119 - Added Ecutek legacy adjustable ID's and Transmit rates
// 1.119 - Added Ecutek Aux Selection item
// 1.120 - Fan3 Duty Enable Change
// 1.120.3 - Change ECUtek RX and TX ID Default values
// 1.121 - Ecutek CX29 Trigger logics
// 1.122 - Fuel Pump Enable, Customisation option
// 1.123 - Short Tooth Gap disable option for noisy looms
// 1.123.3 - Changes to Datalog - INTERNAL - Moved Datalog() out of 250us to Interupt
// 1.124 - Exhaust Pressure to 10bar, Fuel Comp Error Timeout, Sensor Warning Error Flag
// 1.125 - Error Flag System, diagSensErr, diagSensor, diagSensType, Added Gear and CalSelect in Custom axis maps
// 1.125 - Implementing SyncLog
// 1.125 - CANFD support in Generic Transmit
// 1.126 - SyncLog Feature added, when enabled the datalogging will only log sync data and items
// 1.127 - Crank Filter
// 1.128 - Edited CalUp Down Help, Bugfix with CalUpDown and Datastream Slot limited to 10, rep fix
// 1.128.2 - Endianess option not working on Generic Transmit, change CAN Transmit not to transmit 0x400 as default
Firmware Version 1.128 - https://www.syvecs.com/downloads/X20OEX_1.128.3.enc
