LATEST CONFIGURATION(Mapping) SOFTWARE
Locked
Syvecs Staff - Cleaner
Contact:
Post by pat »
LATEST SSUITE AT BOTTOM OF POST
The Below Link is for version 321 (OLD) PC Software with USB Support
Version 321 - Right Click - Save AS
OLD! SEE 332 IN NEXT POST!
Install the SSuite package onto your computer and 6 Programs will appear:
• SCal - Used to adjust the maps in the ECU (Calibrate it)
• SCfg - Used to setup the datalogging (Configure which channels and events to log, and how frequently)
• SData - Used to read datalogs from the ECU
• SView - Used to view and interpret datalogs
• SMon - Used to monitor live ECU parameters
• SMsg - Used to monitor ECU status and debug messages
• SDash - Used to Setup D5 Dash
• SPdu - Used to Setup Power Distribution Modules *Coming soon*
Manual can be found here
http://www.syvecs.com/downloads/Syvecs_Manual_V1.1.pdf
List of Recent Changes/Fixes
SCal – 2.15.316 to 2.15.321
Widen ability to display item values in HEX
Support for more complex menu security
SCfg – 2.15.64 to 2.15.65
Improved export to TXT file
SDash – 2.15.299 to 2.15.307
Support for dash main code 1.4.12 to 1.4.16 added
new checkbox added to LOGGING tab to set logging or Ecu streaming to internal flash (MMC) rather than USB
major overhaul of LinearisationDialog (more like SCal with grid control)
Add new GUI on DISPLAY tab to set both full name and tab name (abbreviation)
Add new GUI on display tab to GOTO page
Add RX datastreams for PduX2 to CANrx tab
Add support for linearisation of CAN voltages - ONLY - 5V at 1mV/bit
SView – 2.15.240 to 2.15.243
Multiple device messages that occur very close to one and other are now combined into a single tooltip on the traces display. Previously it was possible to miss some of the messages.
Text annotations can now be added from the session menu in addition to a double clicking in the traces area.
bugfix –worksheets that included XY plot with 2 Y axes saves in error, invalidating whole workbook
PduXSetup –2.15.1967 to 2.15.1978
There has been a relatively rare but persistent problem with the previous release whereby under certain circumstance a calibration once saved or programmed could not be read back by PduXSetup.
A number of bugs have been found since that last release that could cause these corruptions.
In addition to fixing those bugs, corruption detection has now been built into PduXSetup.
During editing process, the calibration in intermittently checked for corruption.
If found the UNDO buffer can be used to revoke recent edits and take the calibration back to a point where it can be safely saved to disk.
Corruption detection is now also performed immediately before saving or programming.
PduXSetup’s calibration reading has been made more tolerant of some of the errors leading to a previously unreadable file. Now more often than not most of that file can be recovered.
Add IO Summary Dialog
list details on all assigned soft and hard inputs and outputs
provides method to GOTO specific IO item in schematic
provides export to CSV of all IO details
Simulator improvements
add SimulationReset - for power cycle simulation
bugfix - simulator's handling of ALARM state in hard output
bugfix –Correct action of RESET component, should only clear FAULTed outputs
Calibration validation
bugfix - wrong soft output index reported when CAN assignment not found in schematic
bugfix - add validation of properties of EventIn and StateOut
Custom CAN
Add import of LR ECU Generic CAN transmit datastream from ECU calibration
Output Properties Dialog
make more of effort to highlight edit control in focus if text also highlighted
Bugfix - tooltip help text corrected when soft start selected
Major overhaul of Linearisation Dialog (more like SCal with grid control)
Ryan.g
Syvecs Staff - Caretaker
Re: LATEST CONFIGURATION(Mapping) SOFTWARE
Post by Ryan.g »
The Below Link is for OLD Syvecs PC Software with USB Support
Version 332 - Right Click - Save AS
https://www.syvecs.com/downloads/Syvecs ... -04-18.exe
https://www.syvecs.com/downloads/Syvecs_Manual_V1.1.pdf
SCal
Bugfixes
• displaying hex numbers above 0x80000000
• “NOT CONNECTED” option not always visible on PinOut selection
Features
• warn if profile and maincode version dont match during connection sequence (very rare)
• Add "hide restricted maps" to view menu
• Modify output of "Save Pinouts" to make CSV (more easily imported into MS Excel)
SDash –
Warning
o Any Zero-Offset or item persistence setting will be lost on upgrading to main code 1.5.0
o Once the value is re-applied,it will be remembered
Features
• Support for new main codes 1.4.20, 1.4.21 and 1.5.0
• User access to RPM LEDS calibration
• Add Close to file menu
• Add "Clear Internal Logging" to device menu
• Add option to disable page tabs, checkbox on display tab (1.4.21)
• Add checkbox on display tab to make all pages read only (no user editing)
• Add checkboxes to disable Ethernet and Flash notifications on a page by page basis (1.5.0)
• Enhanced User Access for main code 1.5.0
o Duplicates LifeCal’s Comment user access
o Remove user access to
 No of pages
 Disable Ethernet and Flash IN-RACE notifications
o Add fine grained configurable edit access to item attributes on ITEMS tab
o Prevent users moving read only pages
o Default all new calibrations to LIMITED user access
SView –
Bugfixes
• lap beacon not handled correctly in stats report
Features
• For enumerated items, show item value if no known enumerated text
• Don’t show trace data for instances where no known enumerated text
• Add "copy item Text" to channel menu
PduXSetup –
Bugfixes
• Correct labelling of SOFT-START-Capacitive OUTPUTS, should display inrush not softstart setting
• Correct occasional corruption of filename, comment and purpose string in calibration
• Prevent dev/connect when device not running in main code
• Power-Config cannot be SET if connected on main window tab, now offer to disconnect tab to continue
• Set ECU Slave link to CAN2 where calibration is <= 2.17, On 2.19 set to CAN2 if bus not used, On 2.20+ leave selection as is. Add CAN termination too
• Ensure consistent legacy CAN switch panel labelling on schematic IO label and IOSummary dialog
• RESET all faulted outputs when RST_SW toggled ON in simulator
• Labelling of OUTPUT team members not always updated after editing an individual member
• Ensure OUTPUT labels updated after CustomCan dialog OKed
• IOSummary dialog - SOFTSTART (capacitive) uses wrong columns, should display inrush setting
• Input Properties dialog - do not default pull up/down and active high/low on hard i/p assignment as overrides settings that may have been previously COPIED
• Crash or memory corruption connecting/disconnecting to 2.20 cal with more than 64 soft outputs
Features
• Add warnings on file/load, dev/get, dev/set and dev/connect about calibrations before 2.17
• Make highlighted component (one with mouse over), appear on top with opaque background making it easier to read labels of overlapping OUTPUTs (and other components)
• When switching between connected cal tabs preserve device messages
• Add "device\Set & Connect"
• Add “Copy label to clipboard” for right click menu on INPUTs and OUTPUTs
• Add “Retry Count” and “Retry Delay” to OUTPUT properties (and IOSummary)
• Add "Purpose or Role" string editing (cal menu) and display on caption bar
• HardFuseCurrent no longer supports a separate inductive setting (cal menu)
• Change INPUT defaults to Default-on-timeout and Initial-timeout = 2s
• Simulator - StateOut:QTY - add support for input/output value
• Add BOARD_TEMP_3 and BOARD_TEMP_MAX to list of CAN transmittable items
• Add level triggered versions of PCT_COUNTER and PCT_COUNTER_WRAP (as PCT_COUNTER_LVL and PCT_WRAP_COUNTER_LVL)
• Add more friendly error message when cal loaded with unrecognised (new?) component id
• Add new device types; PDUX2B, PDUX3B, PDUX4B and PDUX6B
• Show numbers in CalSize resource bar
• Add 48V operating voltage option, will be supported on new PDUXB range in future
• CustomCan dialog
o Add close/maximize caption styles buttons
o Offer to update frame txRate on TX,TXC when signal rate changed to higher value
o Add "CAN Properties" to “soft” IO menus so CustomCAN setup of specific IO can be found quickly
• IO Summary dialog
o Add IO states/values/currents when connected or simulated
o Add splitters to dialog so screen area for each grid can be fine tuned
o Add forcing via right click menu if connected
o Add "menu" button and access to IO properties dialog (with channel assignment disabled) or forcing options
o Double click IO row to GOTO component in schematic
o Add initial timeout and timeout behaviour
Ryan.g
Post by Ryan.g »
The Below Link is for the LATEST Syvecs PC Software with USB Support and USB Logging
Version 349 - Right Click - Save AS
https://www.syvecs.com/downloads/Syvecs ... -04-15.exe
SCal
Bugfixes
• Crash due to wrong axis selected on strategy - Secure enum on mode select
• Sensor zeroing when more than 8 sensor groups
• Some strategies and most mode-selects affect other parts of the calibration
o Ensure the list of affected maps in the F1 help is the same as those listed in post edit dialog
• Define Sensor Dialog in VC menu
o Correct rounding error in RawMin and RawMax if negative
o Recalculate RawMin and RawMax if scale changed
o Disable OK if RawMin or RawMax out of range of underlying storage unit
• Prevent crash on access to VC menu maps located : Output Functions / Instrumentation / xxx
Features
• USB Logging Support for devices with USB Communications
• Restrict choice of enum elements in same way as values when setting breakpoints
• Clearer 720 degree labels in SyncLog dialog
• Values shown for each enum element in selection dialog
SNetServer – 2.15.80 to 2.15.83
Features
• Increase message timeout to make PDU power config programming more reliable
• Reduce message timeouts for new LifeData ECU download mechanism
Sview
Bugfixes
• missing axis on last trace in "stacked" graph
• crash caused by deleting MATH item from stacked graph
• various problems with dealing with lap beacon in trackmaps
• changes in trackmap affecting split beacons not always applied to sector reports
• Concatenation of data files requiring extra zero sample sequences
• Item preference acquisition in data from dash independent logging not reliable
o Caused worksheet failures
• XYPlot favourites
Features
• Support for USB streamed logging
• Add GPS position of mouse to TrackMap dialog, add option to copy to popup menu
• Improve trackmapping performance on over sampled data
• Add "copy cursor time" to clipboard to status bar
Locked
