I looked in the manual and at the videos, and could not find an explanation on how to convert the error flag number that is produced by the log to the actual error specified by the "error flag items bit assignments".
I do understand how to set the severity by group, but not how to determine what error flag = which fault.
Thanks!
Converting Error Flag Bits to Fault
Re: Converting Error Flag Bits to Fault
Open you error flag channel in SView, highlight this channel. On the bottom of the screen will be the decode for the channel. In my case it is the channel syncFault See below bottom screenshot.
In brackets is the hex value of each fault, get your trusty Programmer calculator and from there you can see what bits are active for each fault. In this case Tooth Timeout(6) will be bits 1 and 2 active or 0x06h
That should work..
That should work..
- bitcalc.png (2.2 KiB) Viewed 1265 times
- syncFault.png (4.92 KiB) Viewed 1265 times
@littlefella thank you for looking.
I've attached a screenshot with the cursor on limp mode; error flag is 1024 (lambda 2 in my case) and limp mode shows "sensor warning level".
I'm not seeing the decode like yours, maybe I'm missing where to look. Thanks again for the help.
- Screenshot 2023-06-07 at 8.32.49 AM.png (112.75 KiB) Viewed 1259 times
Seems some channels are not in ENUM Can't help sorry, need to ask directly I think, you need a decode document.
The error flag may be converted straight into a fault message if your Syvecs system has any diagnostic software available.EOG wrote: ↑Mon Jun 05, 2023 6:06 pm I looked in the manual and at the videos, and could not find an explanation on how to convert the error flag number that is produced by the log to the actual error specified by the "error flag items bit assignments".
I do understand how to set the severity by group, but not how to determine what error flag = which fault. Buckshot Roulette
Thanks!
