Dual injector Control
The Syvecs WMI controller is a compact but very powerful unit for controlling a complete Water Injection electronics system, safely and correctly.
Dave-uk
Post by Dave-uk »
Currently using a Syvecs WMI module with the latest Firmware.
The module is wired in to a 2018 TTRS.
is it possible to program independent control of injector output 1 and 2. Output 1 is installed in to the charge pipe with a single nozzle to provide charge cooling, output 2 is installed in to a 5 way distribution manifold for the port injectors.
In a ideal world it would be great to be able to set to 2 cals, one with both injectors firing for meth dependants ECU cals, and a single firing for ecu cals that only need the cooling effect.
Lqqk
Re: Dual injector Control
Post by Lqqk »
+1. Dual injector control would be fantastic
Return to “Syvecs WMI Module”
