Help connecting V2 BT module to N54 PnP S7+ 1.699 sw
For support and updates on the Syvecs Bluetooth module
Moderator: Wez
beetos
Post by beetos »
Hi, N54 PnP kit.
I have wired in my V2 BT module to the RS232 TX/RX. However, the instructions don't relate to my software version (the referenced features in the instructions don't appear to be there).
Instructions say set datastream to custom CAN, cant find that option on my software. My software options relate to CAN bus 1 and 2. CAN 1 I believe are all the PnP functions. CAN 2 is set to 1MHz. There are options on ‘Generic CAN transmit’, all frames are set to CAN2. Frame identifier are all 600h and transmit frequency vary from 10 to 100hz for frames 1-32.
Further down on the menu RS232 is set to CAN Echo, and frame rate 10hz, with no option for 20hz (called out by instructions).
Can anyone advise how to set it up? Of course I still need to replicate the transmit content slot/frame in the BT IOS software, shame there is no N54 PnP quick set up.
Any guidance to get the BT module working much appreciated.
Thanks.
beetos
Re: Help connecting V2 BT module to N54 PnP S7+ 1.699 sw
Post by beetos »
Thanks to Syvecs support, firmware 1.711 allows the options required for RS232 stream specifically for the BT module.
