Can anyone bump me in the right direction?
Im trying to get my a/c to work on my s6 but unsure of which i/o should be assigned. Any help with the matter is much appreciated. Its an 04 sti.
A/C pin assignment newage sti
Re: A/C pin assignment newage sti
Have you checked the forum section for the S6 PnP pin assignments?
Hi I'm trying to connect an ecu master can expanded into can l and h on the ecu board. However I'm having trouble.TimH wrote: ↑Wed Jul 14, 2021 1:38 pm Have you checked the forum section for the S6 PnP pin assignments?drift hunters
For what purpose exactly ? I'd doubt the ECU master would be compatible ?
S6 cannot receive additional inputs via CAN. Is this S6?stevieturbo wrote: ↑Fri Nov 17, 2023 10:17 am For what purpose exactly ? I'd doubt the ECU master would be compatible ?
If S7, with 2x CANbus, you can receive data via CAN and the ECU master expander can almost certainly be configured to work.
