default gauges
CT9A
default gauges
Post by CT9A »
How can I get the default gauges in Scal, I did a full uninstall and reinstalled, still no default gauges.
Re: default gauges
Maybe choose one of the provided gauge layouts, or create your own and save it, then set it as default?
CT9A
Re: default gauges
Post by CT9A »
I mean there are no provided gauges, and that is what I am looking for. How to get them?
Re: default gauges
Not sure I follow? Are there none listed under the "Gauge" menu?
CT9A
Re: default gauges
Post by CT9A »
Yes non under the gauge menu, were there normally is a whole list of preset gauges.
Re: default gauges
Oh, OK. Weird. Never seen that, sorry :(
Re: default gauges
Maybe try a full uninstall and then fresh install again ?
I dont think mine has ever installed without them, although I rarely use the as supplied layouts anyway.
I'm sure they're probably stored in the registry somewhere that they could be imported via that means, but dont think there's an easy external way to grab a lot of them and import them. Although you could save a lot of layouts manually and export them from another install, to import them on yours.
CT9A
Re: default gauges
Post by CT9A »
I tried a full uninstall and reinstall, still no gauges.
Re: default gauges
Weird.
MReilly
Re: default gauges
Post by MReilly »
Nothing to do with allowing the program administrator rights on your PC?
