Cal version change ?
Is the software dated 21 July 2015 the latest ?
If I try to change the software version of my Cal file to that of the latest firmware, ie 1.57, my current software version isnt allowing this whilst offline.
Just curious to see what's been added and deal with any error flags before changing.
pavlo
Zen Performance
Re: Cal version change ?
Post by pavlo »
You will need to be online for some operations.
Have you run the firmware exe first? If you've done that the profile for 1.57 should be stored locally.
Paul
I was just seeing if it would import offline to see what changes it flagged up, to see if it would be a ballache to change.
I flashed 1.57 in and imported my map across earlier, then flashed back to 1.5 so will take a look at it later offline.
