Sorry if this has been covered before..
Can anyone give me a recommendation for a non-LSU wideband lambda sensor for S8? I want something that is accurate, user friendly and utilises the onboard controller.
I seem to remember Ryan (I think) mentioning that there was a sooper-dooper motorsport oriented sensor that he recommended. Anyone know what that was or can tell me what Syvecs recommend sensor-wise?
I WAS swaying towards an external LSU 4.9 but I'd rather not use up an input when the onboard controller exists.
Many thanks....
TT
What Wideband Lambda?
Re: What Wideband Lambda?
There is a high grade NTK available - Pat should know the part number - and that's what the S6 and S8 were designed for, I believe. The circuitry does not make use of the calibration resistor in other wideband sensors, so for perfection you either need a lambda with factory-matched characteristics (which is, I think, what the super motorsport grade sensor is) or you need to characterise each sensor. Expensive, or tedious.
However, the circuitry works with the NTK "L2H2" sensor. This sensor has a basic linearisation that is near as darn it the same as the motorsport version but does usually have a small offset. What is generally recommended with the L2H2 is to compare it during mapping to an external lambda, such as a Bosch LSU 4.2 or 4.9, and then adjust the lambda targets to suit.
The error is generally very small - perhaps .01-05lambda I think.
I keep meaning to try a number of sensors in free air and see if I can correlate the free-air lambda voltage with the built-in lambda calibration resistor - that way I might be able to come up with a free-air calibration routine of some sorts
I'm not sure but Pat probably means this Motorsport(Laboratory) wideband sensor,price is $399.99 which is not bad price
http://www.bmotorsports.com/shop/produc ... cts_id/647
Jura
Jura
tarmac terror
Thanks Jura, had found this one myself a couple of weeks back. I assume that this IS the one Syvecs recommend but just want to be 110% sure before buying one.
Thanks for taking the time to post
. If Pat or Ryan could confirm that this IS or ISNT the right one then that would be much appreciated...
TT
TT
tarmac terror
Can anyone confirm please...
TT
TT
tarmac terror
Can anyone tell me where I can buy the recommended wideband lambda sensor and how much it is please??
TT
TT
