honda 3 wire denzo coils
Re: honda 3 wire denzo coils
forgot to say second bank r mike moran injectors
hi pavlo just to clarify coil wiring, do you mean +12 and signal together and ground to ecu or +12 and ground to coil and signal to ecu .and where does resistor need to go
Like I said it depends on how you want to do it.
ONLY FOR COILS WITH BUILT IN AMPLIFIERS:
To run them as normal TTL (so thats +5v signals that got high for the dwell time then back to ground) connect the +12v on the coil to ignition switched +12v, ground to engine ground (however you choose) signal on coil to ignition output from ECU. I used a 200ohm resistor between the ignition output and ground but many coils don't need anything. Set the Ignition output type as TTL and TTL voltage to 5v.
thanks for help ,steve
