Re: Latest S6 Firmware
Posted: Fri Apr 01, 2016 2:44 pm
This Link is for version 1.64 of the S6 firmware.
PLEASE ENSURE LATEST SSUITE SOFTWARE IS IN USE BEFORE UPGRADING FIRMWARE!!!
http://www.syvecs.com/downloads/SyvecsS ... -03-22.exe
Help Video on Firmware below
https://youtu.be/IVIdYESOuOQ
Updates from 1.59
* VK56 crank pattern support
* rpmDTR calculation
* idle control rpmDtr axes as S8
* gear cut enable throttle threshold as S8
* add PPS option for TPS/PPS axes in ALS strategy
* 4 Car Code options
* key on bap from ccp1
* engine coolant presure Trip from S8 (default OFF in cal switches)
* separate fuel advance and retard rate limits
* wg enable map-bap offset as s8
* vvt / cam sensor allocation - copy vvt/phase shared pin config checks from s8
* monitoring items for slave inputs 25..28
* pitch and roll sensors
* lr gps receive enable now differentiates original (gps-a10) gps box and new gps-ag50
* change gpsSpeed from knots to kph
* expect gpsSpeed gps-ag50 to be in kph
* translate gpsSpeed receive from gps-a10 from knots to kph
* latg/long/vertg/yaw/pitch/roll from lrgps subject to sensor zeroing
* 25 configurable sensors as S8
* eight configurable fans as S8
* bbw split into two configurable basic pwms as S8
* 20 configurable maps as S8
* cm use : Global Fuel Multiplier
* cm use : Global Ignition Adder
* cm use : BP01 Duty Multiplier
* cm use : BP01 Duty Adder
* cm use : BP02 Duty Multiplier
* cm use : BP02 Duty Adder
* cm use : Fan 3 Duty Multiplier
* cm use : Fan 3 Duty Adder
* cm use : Fan 6 Duty Multiplier
* cm use : Fan 6 Duty Adder
* cm use : Fan 7 Duty Multiplier
* cm use : Fan 7 Duty Adder
* cm use : Fan 8 Duty Multiplier
* cm use : Fan 8 Duty Adder
* cm use : TrqEstMbt Multiplier
* cm use : TrqEstMbt Adder
* cm use : LaunchRpm Adder
* rpmDTR available as cm axis
* dbwTargBlip available as cm axis
* new monitoring item closed loop idleActiveTime (stops at one minute)
* idleActiveTime available as cm axis
* new cm map use : idle target adder
* new cm map use : idle base duty adder
* new cm map use : dbw target limit
* new cm map use : gear blip target adder (can be -ve)
* new cm map use : gear blip time adder (can be -ve)
* calSelect available as cm axis
* tcSelect available as cm axis
* new cm map use: auto trans line pressure duty multiplier
* auto trans alternate line pressure shift duty in sport mode
Updates from 1.59
