Hi - Am I right in thinking I can use "Engine Enable Throttle Position Threshold" under 'Starting' to help clear a flood / engine flooded situation?
Ie I set to say 75% and so when the throttle is floored the Engine becomes not Enabled so the injectors cease to fire?
-Ed.
Re: Engine Enable Throttle Position Threshold
Actually now I look at it this function (clearing engine during cranking) is controlled by the base fuel injection table under 'starting' - so now I'm a little unclear of why you'd need the 'Engine Enable Throttle Position Threshold' table at all.
-Ed.
-Ed.
Engine Enable relates to more than just fuel injection. So whilst it is true that you can have a flood clearing feature by setting the base fuel down to zero at higher TPS in the starting map, what you cannot do is to prevent the pre-injection pulse nor can you prevent sparks from happening. When the engine is disabled, it means that other actions are also disabled.
Thanks Pat!
