More water / meth injection
Here is the final set up after testing many iterations and all scenarios, this works tip top
So no more need for the 3rd party controllers or cables etc, just a pump, jets, high speed valve/s, and flow meter/s to suit the specific set up needs.
You will need a PDU, Dash to compliment your ECU though, which is fine as most have this anyway.
The strategies are complete and more integrated than before which is what you want in a true water injected car
Note: we do run all kinds, from pure RR mechanical to hybrid RR mechanical (controlled through ECU), to Aquamist (partial control through ECU), to now full control through (ECU + Dash + PDU)
Last little while I have been working on the latest generation of Syvecs water injection implementation.
Deviates from the above in that its fully sequential, and is tied in 100% the fuel related strategies of the engine control, this results in lower fluid use and otherwise normal operation regarding delivery (it is not a patched on system you need to work around). You have to use a LR/Syvecs D4/D5/D8 dash and as well as a PDU to get the full benefit but its worth doing. A few tests were conducted and new external software developed to simulate all of the permutations to gain the right set up. Some compatibility in hardware parts and mixtures (basics) to cover off parts that can go together to make it all happen.
Once I get onto the next stage of advancement I will happily put up this when it becomes 'old hat' but for now I can say its what WI should and can be as a fully functional part of the controls running the engine.
WI the final solution http://www.riceracing.com.au/Donmega_Waterinjection.htm
https://www.youtube.com/watch?v=q-9XuyVY1Ds&t=11s
^ Here is a 10 minute or so 'rape' video showing WM50 usage on a mild set up, its easier to put up here than answer multiple times
Rough ratio of fuel used V WM50 used from time on load for reference.
Current system parts, remainder is 'conventional' and brains is controlled by Syvecs/LR no 3rd party controllers or 'Telephone cables' to be seen
System low level and content sensor
- WM50 voltage.jpg (535.8 KiB) Viewed 239677 times
Here is the Aquatec (large pump) being PWM driven directly from the S8 and PDUx3.
Tested from 0% to 100% and works ~3% duty onwards
With this latest set up we have control range of:
For those who want to program it all themselves this is how I do it (you will have to work out your own maths though).
The dash math items have a raft of inputs/outputs from the PDU and ECU for example to show things like if the WM injectors are at fault or pump to name but two items. There is a stack of basics like trip values for the associated sensors in the system which I have not shown to not bore you all !
To do it fully without going mental I also added to the calibration sheet to test run all combinations to allow quick narrowing down of what parts would work to give desired system fit this takes into account basics like injector type/characteristics, scheduling (360 or 720), pressure heads, varying rates of rise to map, ratios of fluids used,
Dash Items: (math and CANtx)
- ~20% to 100% (by mass) to main fuel supply adjustment range
- Full fluid mix ratio control, any percentage of WM allowed 0 to 100%
- Complete integration in with fuel control strategies in ECU IE: full sequential
- fmt (fuel mixture trim)
- wiFlow (per bank etc)
- wiFlow (total)
- wiStatus (water injection status)
- wm50relP (water injection pressure)
- CM3* wg*adder (cal select and wiStatus)
- CM3* wg*adder (wiFlow and map)
- Injector Split (adjust supply)
- CM3* fuelMlt (wiFlow rpm)
- CM3* fuel Mlt (cllTarg tpsMax)
- CM2* cllTargAdd (wiStatus)
- CM3 cllTargAdd (rpm fmtSwitch
- CM3* ignAdd (wiFlow)
- U* (wiStatus)
- U* (wm50p)
- U* (fmtSwitch)
- U* (wm50Lsw)
- R* (wiFlow1)
- R* (wiFlow2)
- R* (wiFlowTotal)
- R* (wm50relP)
Here are a couple of shots of parts of the calibration sheet that allows different permutations of set up variables to be tested prior to selection.
There is more to the sheets than above, some of it is ability to look at pump flows/duty correctly (both main and WM) these obviously interact depending on split and fluid specifics like pressures for example. Very important to be able to this as there is really no way to do this efficiently without a shit load of guess work *good luck* trial error tuna time.
Tied all back in to calibration settings like below: Have ability to quickly change based on driver selection, to max WM flow rates to min (economical) ones. It changes pump PWM and CM fuel corrections automagically
Hopefully gives enough insight for what I would call an advanced WM integration.
Did some more set up work on this, now looking at the three chamber pump head and motor to optimize the current draw and linearity to duty cycle applied, there are some interesting spots of frequency applied to the motor where it is not as happy (big effect on pressure variance). Did over 30 tests over a day from 40Hz to 500Hz some pics below... Have the Grayhill keypad integrated in there too.
