I was actually going to try throwing a 1k resistor in parallel with the led just to see if that would pull it away enough, I know the current wil be negligible, I have some other values I could try too. I can do it inside the shift light as stated I have gutted the inside.
I actually have another shift light with a filament lamp, that would solve a problem haha, the led is just a little more subtle
Wiring led from ecu output - constantly dim
Re: Wiring led from ecu output - constantly dim
