I do quite a few of these and thought I would put up a few examples of my standard templates as well as a video showing cycling through the various screens.
Have set ups for the D5 and the D4, the later offering closer mounting on the binnacle viable inside the steering wheel.
Software example of action of traction control severity via optional maths in the dash unit, which makes it very powerful, and most people select PRO versions of these to allow other nice benefits like unlimited USB logging. https://www.youtube.com/watch?v=IEtW_ItR8Dg
D4 examples
Re: Syvecs Dash Examples
Posted: Sat Aug 03, 2019 4:07 am
I get allot of questions if these dash's like "are they direct sun light readable?"
Best way to answer that is with a proper shot/s below. Keep in mind this is basically the sun (Australian sun lol!) where its powerful! and if tilted any more its just like looking into the sun itself and it will damage your eyes let alone the camera
The dash's are amazing, and with my config they are legible in all conditions, hard to get across with a picture but it is like its projected onto the screen face, there is no amount of direct sun light that effects the view of the important data. Allot of time has been spent on the back ground text and color ranges to make it the best it can be for quick and easy reading, its intuitive with the right balance of quickly understood graphical positional information for most channels and a numeric component for extra detail.
For those who want to mount to steering column and need to use all the IO of the D4, D5 this is one way to do it, use the below connector and solder pins then pot and will allow flush mount options pretty easily. Gets interesting soldering the middle row of pins, but if I can do it anyone can
Posted: Sat Feb 22, 2020 10:31 am
D4 column mount I made
Posted: Thu May 14, 2020 1:24 pm
Got a new scale available so non important ranges can be compressed, in this case 0-4k rpm
yo scale 1.jpg (365.25 KiB) Viewed 71758 times
yo scale.jpg (211.36 KiB) Viewed 71758 times
Posted: Tue Jun 23, 2020 3:52 am
Above video to show the RR highly honed/developed D4/D5 dash display solution. These have been in constant state of development for last 5 years to point now where its what a dash should be, simple and driver friendly.
A dash is useless if it has bullshit colours all over the place making it unreadable let alone in adverse lighting conditions, same for random invalid ill thought out alarms that flash up everywhere when they don't need to be doing so. It taken us years to get these to this point. There are more than 65 different alarms/warnings/change page items that cover all of the basics like sensor limits, ECU actions, state changes and so forth. All of them are simple and logical, all the driver has to do is focus on driving! and only pertinent information will be displayed or changed to that display as and when it is deemed necessary.
They are the most legible dash displays you will see, viewable and understandable at a glance, no need to try to quantify seemingly meaningless pages of just numeric data, which is impossible in a race car or high powered road car.
Posted: Thu Aug 05, 2021 12:46 pm
Above is showing the ability to overlay gear change state to the Syvecs D4 dash for an effective shift light without need to use LED's. Also you can see the light sensor working which can be set up to change lighting intensity depending on lux value seen.
Nice unit
Posted: Thu Oct 26, 2023 12:59 am
I did the first major revamp of this since OG set up in 2016 or so......
User flexible scales and arrangements not tied in to custom back grounds, more race oriented and the only dash that works in periphery of your vision as they all should do if its a 'real' dash' some pics below.
mindon 1.jpeg (199.51 KiB) Viewed 44084 times
Posted: Thu Oct 26, 2023 1:08 am
literally test these for hundreds of hours across different users and applications, I have over 80 different alarm/warning/message/change page items that all work seamlessly, when combined with the virtual switches in dash to allow launch control, fuel mixture control and physical switching of calibration and traction then the maths section tied into a syvces/LR PDU this combination is really gagfactor3000
minidon 5.jpg (124.87 KiB) Viewed 44084 times
minidon 6.jpg (141.25 KiB) Viewed 44084 times
custom final change light page (which grabs your attention no matter where you eyes are looking !)
