MAP Sensor readings
MAP Sensor readings
What sort of values should I be seeing with the engine not running and with engine at idle with a 4 bar sensor - thanks
Re: MAP Sensor readings
Atmospheric should be around 1000mbar, give or take.Arch wrote:What sort of values should I be seeing with the engine not running and with engine at idle with a 4 bar sensor - thanks
and at idle, 200-600mBar usually.
Thanks guys appreciate the help
